Editable D-style schematics
10thTx
Re: Editable D-style schematics
Post by 10thTx »
This Bandmaster Ultra Phonix mod schematic is a guess and may contain errors. There was some discussion on the thread that the slope resistors (tone stack) are 47k which explains the difference between the editable version and the "edited Fender" version by Aaron Giffin.
The thread is here: http://ampgarage.com/forum/viewtopic.php?f=4&t=30285
With respect, 10thtx
Drumslinger
Post by Drumslinger »
Excellent! Thanks Jeff!
10thTx
Post by 10thTx »
Tony was kind enough to share a schematic which will be referred to as D-33-109 . [/i]PLEASE check for ERRORS! And compare this editable version with the "original" version that Tony shared. It should be noted that the original version likely contains errors.
* NOTE: Please read Talbany's helpful response two posts down regarding this schematic.
AND note the links provided by Martin Manning which reference useful info for consideration also.
I have revised the editable SCH version to reflect as many of Talbany's edits as I am able to understand.
It also may be of use to look at the D-40 schematic IF you are attempting this build.
EDIT 3-9-2019 : I have added an editable schematic that is based off Talbany's "2nd Generation 50W" layout. PLEASE compare carefully with the layout and look for ERRORS. https://ampgarage.com/forum/viewtopic.php?f=5&t=12870
I'm not sure that Tony is the originator of this 33 schematic: http://ampgarage.com/forum/viewtopic.ph ... 10#p384310
Perhaps he or someone else can comment on the actual source?
Edit: See linked thread... Traced by a Japanese builder.
talbany
Post by talbany »
Jeff
To answer your question?.No I did not draw the #033 schematic I posted!.The schematic was posted a while back and given to us by Andy Fuchs from someone in Japan.This was before we/I had any info on the earlier 2nd generation amps.The switching that you asked about should be as per my 2nd gen layout here http://ampgarage.com/forum/viewtopic.php?f=5&t=12870
Questions and possible changes I would make to your schematic are.
1 The difference between the earlier 2nd & 3rd gen and later 4th gen/transitions are,
he grounded OD while in clean mode to avoid bleed back and ghost notes from occurring.
2 I believe he missed the ground wire on the OD network (under the board) so I would add that to your schematic.
3 The high 4/9 Meg grid to cathode (grid leak bias) resistors on the 1st 3 stages I suspect are a later modification since I have never heard of Dumble grid leaking any of his designs but there is no way to know for sure?. :?
4 The PI on the drawing is also suspect (100k plates 47k cathode?).Dumble used 47/51k Rp w/470 Rc using an AT7
If you want to do another IMO improved version of this amp I recommend using the later 4th gen relay design and axe the grid leaks and add in a 56K grid blocker on V2a as well as the correct Dumble values for the PI.This would be more in-line with the period correct 2nd gen w/updated relay network.
The loop looks good coming off the stack (before the vol) and mixed back in,in phase at the PI (220k)
I believe the level to be a 1M not a 2M as I think this is a mistake as well!
Let me know if I can help further!
Thanks, Tony. I've already added an updated relay layout in the linked "Period Correct 2nd Gen" thread. http://ampgarage.com/forum/viewtopic.ph ... 85#p383685
talbany
Post by talbany »
martin manning wrote: ↑Sun Apr 22, 2018 12:27 pm Thanks, Tony. I've already added an updated relay layout in the linked "Period Correct 2nd Gen" thread. http://ampgarage.com/forum/viewtopic.ph ... 85#p383685
Martin
This is a great addition to the thread! 8)
Thanks!!
10thTx
Post by 10thTx »
Talbany shared some information and photos about a tan MusicMan Dumble. http://ampgarage.com/forum/viewtopic.php?f=4&t=31194
The 3rd page of the thread, Tony lists some specs:
Hey I found the 200-130 specs.
200-130Primary 120v
High Voltage Sec #1 Sil Voltage Doubler (F.W.) (2) 100mfd
Brn- R/Y 710vdc @ .100a, 660vdc @ .275a
Red- R/Y 440vdc@.275a
Low Voltage Sec #2 org - yel- org
Sil. Bridge (2) 150 mfd cap + - 42 V 0A 60V CT @ .1 RMS
Filaments (2) 6.3V @ 6 A grn- grn/yel
The thread also referenced another thread on Music Man Dumble clone http://ampgarage.com/forum/viewtopic.php?f=4&t=18960
Attached is the SCH schematic of the Music Man power supply which was drawn by Pompeisneaks (Phil)
Respectfully, 10thtx
pompeiisneaks
Site Admin
Post by pompeiisneaks »
I won't go editing your post 10thtx, but that one above has some errors, I've updated it per notes from the other thread. Here's the latest, if you want to nuke the old .sch you have above please do so, or let me know and I can.
Edit: Fixed again due to another error Charlie Wilson found. and only going to update your post above from now on :D Thanks 10thtx
cgmason1986
Post by cgmason1986 »
Does anyone know of a link to download the mac software? The original link posted doesn't work anymore.
pompeiisneaks
Site Admin
http://jschem.bplaced.net/
The original software doesn't support mac but this software edits them just fine.
jabguit
Post by jabguit »
pompeiisneaks wrote: ↑Sat Oct 09, 2021 4:29 pm http://jschem.bplaced.net/
My download of this contained a virus. Just so you know.
cheers,
Jack Briggs
Briggs Guitars
pompeiisneaks
Site Admin
jabguit wrote: ↑Sun Oct 10, 2021 11:08 am
cheers,
Could you clarify how/where/why?
I just put three things through a thorough scanner that pushes the scan against like a hundred known virus scanners, including some very reputable vendors, and they were:
the dmg file for macos
the exe file for windows
the entire website http://jschem.blaced.net/
Found exactly 0 viruses... Are you sure that there wasn't some warning about an unsigned app or similar that windows and macos now require for an app to be considered 'safe' by their standards? This is a wise protection, but not all code developers like this app have the resources to pay for a code signing certificate.
If you could clarify what exact 'virus' message yours had, or what virus scanner found it, I'd appreciate knowing.
(For curiositys sake if anyone wants to try scanning these how I did, check out: https://virustotal.com/
lets you do scans against many, many different AV engines. and I highly recommend you use it often for apps you download from the internet if it's seeming to come from a somewhat 'weird' place)
jabguit
Post by jabguit »
pompeiisneaks wrote: ↑Sun Oct 10, 2021 4:47 pm
cheers,
Can't give any details - just that my virus software (Panda) flagged it and put the download in quarantine.
cheers,
Jack Briggs
Briggs Guitars
pompeiisneaks
Site Admin
Ok never heard of that one before, and just as an FYI my job is in IT and understanding security. I looked them up and the review I found of them was from PCMagazine (pcmag.com) and they gave it a 2.5 out of 5 rating. Seems it missed some pretty bad malware, and my guess for this case is that it's getting a false positive on the jschem software.
You may want to look for other alternatives. If you're on windows the built in windows defender for windows 10/11 is pretty highly regarded. If you're not, and on windows I highly recommend AFG Free antivirus. Their free verison works pretty well and gets decent reviews.
For mac I don't honestly know as well. I've not used a personal mac for over 10 years at this point. Work provided me one for a long time and they use one of the corporate ones like symantec or mcafee which are both known to be horrible... but I digress :D
I'll end my side path here off topic on that.
